1. After you find the center point where the holes are going to be, use a nail and lightly tap it into the center point to make a mark so the drill bit will be lined up properly.
2. When cutting out the holes apply light pressure and let the saw do the work.
3. As you cut through, make sure the drill and saw are perpendicular to the work piece.
4. Move the saw in and out of the hole very slowly once you begin cutting - this helps the sawdust escape so the saw can cut deeper. Drill the hole in several steps if you have to.
5. Make sure you clamp the piece to the work bench with a sacrificial piece of wood or MDF underneath. You don't want to ruin your work bench! It took way longer to do all of this stuff than I thought it would but that's always the case and I should know better by now not to plan too much ahead. Next weekend my father is coming over and we are going to put everything together so it should start looking like a real arcade cabinet by then. I can't wait.
