The buttons, t-molding and joystick ball top will be a darker pink from Dream Arcades to accent the cabinet. I've ordered the following parts so far:
3 pink buttons:
1 pink joystick. I only ordered this for the ball top. I'm actually going to be using the Ultimarc 360 joystick for this project but it does not come in pink. Most joystick balltops are just threaded on to the shaft so I'll just unscrew them and make the easy swap.
30ft. of pink t-molding. This is a plastic trim which will go around the edges of the sides to give the cabinet a finished look.
As for the marquee artwork, right now I'm just planning on a bright colorful marquee - the control panel will be covered in black vinyl so the buttons really "pop" and I don't what type of artwork I'm going to add to the sides yet, if anything.
