One final thing that had been bothering me was the fact that I had to open the coin door to hit the power switch on the computer in order to turn everything on and off. I decided to relocate the power button from the front of my computer to the rear panel on the outside. It's out of sight but easy enough to press before and after a play session.
One consideration was that I wanted the button to be recessed in the panel - I think it looks nicer and whatever small chance there is that it will get pressed accidentally is greatly reduced. I had to come to terms with drilling through my awesome finish on the rear panel - oh well, it's necessary I guess.
Anyway, I wasn't sure about the placement of the button so I actually thought about it for quite some time. I wanted it to be out of the way, easily accessible and aesthetically pleasing in it's ultimate location. I think I achieved all three of these things. I decided to place the button towards the top of the cabinet because it would be easiest to press in that location.
The first thing I did was lay out the center for the button hole using some painter's tape (so as not to mark up the actual cabinet. I measured in from the right to the exact center of the power plug to line up the button hole (for aesthetics) and then measured down from the top the same distance and made a mark and tapped out the center with an awl:
...and here's the button all wired up but not installed:
I am VERY happy with the way this worked out. The button is very easy to reach and it looks great - everything is tied into it. You press it once and the computer powers on, the marquee light comes on, the speakers power on and the LED coin door lights light up. The computer boots straight to whatever the last game played was. Press it again and everything shuts down. This definitely beats opening up the coin door and contorting my hand to reach the power button on the computer!
